Change the primary or secondary boot configuration file to specify which configuration file the system uses to start.
Configure the primary boot choices.
You have a primary configuration file that specifies the full directory path and a secondary configuration file that also contains the full directory path.
Switch:1> enable
Switch:1# configure terminal
Specify the configuration file in internal flash memory as the primary boot source:
Switch:1(config)# boot config choice primary config-file /intflash/config.cfg
Switch:1(config)# save config
Switch:1(config)# reset
The following table defines parameters for the boot config command.
Variable |
Value |
{backup-config-file|config-file} |
Specifies that the boot source uses either the configuration file or a backup configuration file. |
WORD<0–255> |
Identifies the configuration file. WORD<0–255> is the device and file name, up to 255 characters including the path, in one of the following format:
